router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
router_exe
Apr 16, 2011Aspirant
so, i can't get 4.1.7 to actually install, but i can get the 4x version in the tftp download to install.
new plan...install 4x on a 250gb hard drive, upgrade to 4.1.7, start hot adding the 2tb drives, pull the 250gb, hot add last 2 tb drive. will this work?
