router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
mdgm-ntgr
Apr 17, 2011NETGEAR Employee Retired
Oops. I meant to say that to get 4k sector alignment a factory default on 4.1.7 if necessary. If you don't do this factory default write performance will probably be poor as your disks are 4k sector disks. This is clearly mentioned in the 4.1.7 Release Notes
