router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
router_exe
Apr 17, 2011Aspirant
oh ok. i feel like i'm losing a battle with this. one 2tb hard drive plugged in. 80mb cf card with 4.1.7 on it, doing a factory default. raidar picks it up, and i tell it to use xraid, then it does some dancing with the greed leds, and now, 30 minutes later, all it's doing is blinking the blue light slowly. raidar doesn't see it. i can ping it. not sure what it is doing. :(
