router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
router_exe
Apr 18, 2011Aspirant
write performance seems to be ok, but i'm not sure what is poor. it just won't do a new install with 4.1.7, so i guess i have to work/live with it the way i did it unfortunately :(. every time i try 4.1.7 i select xraid, and then it starts to install normal, and then nothing. just slow blinking blue light, and no response from raidar.
