router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
Pittspilot
Jul 08, 2011Aspirant
I have this problem too. I have tried downloading 4.1.7 and copying it to a (different) CF card, but the 600 is not reading it (I still get the blue flashing and 1&3 green led).
I need (idiot-proof, non-techy) instructions on how do get the CF card formatted and the Radiator image onto it. I tried NTrawwrite, but it fails (On WIN7) but the window closes before I can see the error message.
Help!!!
Cheers
Help!!!
Cheers
router.exe wrote: I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped detecting the nas. only the power led was on doing a slow blink. i could ping the device...so i rebooted the device into factory reset again. now, i get the LED pattern for "Boot loader fails to locate valid RAIDiator image". I've tried TFTP booting, and that doesn't seem to be working. once tftp finishes i have a amber leds flashing 1234 and 1/3 back and forth. the led list doesn't have an entry for this. not sure what my next steps should be.
thanks in advance.
