router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
Pittspilot
Aug 03, 2011Aspirant
I really need some help on this. I have a dead 600 that will not boot. It seems that I need to get the OS (4.1.7?) onto the CF card so that the 600 will boot and then do it's stuff.
Can anyone help me with how to get RAIDiator images onto the CF card so it will boot?
Cheers
Cheers
Pittspilot wrote: I have this problem too. I have tried downloading 4.1.7 and copying it to a (different) CF card, but the 600 is not reading it (I still get the blue flashing and 1&3 green led).
I need (idiot-proof, non-techy) instructions on how do get the CF card formatted and the Radiator image onto it. I tried NTrawwrite, but it fails (On WIN7) but the window closes before I can see the error message.
Help!!!
Cheers
router.exe wrote: I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped detecting the nas. only the power led was on doing a slow blink. i could ping the device...so i rebooted the device into factory reset again. now, i get the LED pattern for "Boot loader fails to locate valid RAIDiator image". I've tried TFTP booting, and that doesn't seem to be working. once tftp finishes i have a amber leds flashing 1234 and 1/3 back and forth. the led list doesn't have an entry for this. not sure what my next steps should be.
thanks in advance.
