router_exe
Apr 13, 2011Aspirant
x600A won't boot
I upgraded the disks my x600a to 4x2tb, and did a factory reset. prior to upgrading the disks, i upgraded RAIDiator 4.1.7. First go around, everything seemed to go normal, and then RAIDar stopped de...
Pittspilot
Aug 03, 2011Aspirant
router.exe wrote: i wound up flashing the cf card with 4.1.5 i think. i then installed with one hard drive in the box. after installing, i upgraded to 4.1.7. i then hot added the rest of my drives one at a time. the box recognizes 6tb available as it should.
How did you flash the card, i'm struggling with that (see next post following this one).
