Lewad
Feb 04, 2018Follower
x64 firmware installed on x86 hardware
Hi, I recently purchased an old Netgear ReadyNAS 2100 v1 (RNRX4000) to create an extra off-site backup. I discovered it is possible to update this to the latest firmware, and not to stuck with t...
JohnCM_S
Feb 08, 2018NETGEAR Employee Retired
Hi Lewad,
Welcome to the Community!
To be honest, there is no way in reverting back to the previous firmware on the boot menu. Let us wait patiently for any recommendations from any community members who experienced the same issue.
JohnCM_S
NETGEAR Community Team
- SandsharkFeb 08, 2018Sensei
Since you still have to use the OS4.2 USB recovery mode on a legacy unit running OS6 and you can still get to the boot menu on your system, I believe that the OS6 upgrade doesn't touch the boot loader. If that's true, then USB recovery should still work. See RAIDiator-4-2-USB-Recovery-Tool. Note that the NASes can be picky about the USB device you use. So if it doesn't work the first time, don't give up, try another brand (unless somebody more knowlegable says this can never work).
There is a 4-pin serial port on the back of the 2100. I suspect that, like the NVX, it's a TTL Level RS-232 port, not full RS-232 levels like on some units, but you should look at the voltages before you take that as gospel. If you Google ReadyNAS Serial Port, you'll see some info on connecting to it. But how to use it to recover the flash, I have no idea.
