jeremyotten
Mar 25, 2010Aspirant
XenServer storagelink integration
Please get Citrix XenServer certifified and also certified for the XenServer cool Storagelink feature..
lasseoe
May 10, 2010Aspirant
It's not Citrix who has to integrate with ReadyNAS, it's the other way round. Netgear would have to write code to support the StorageLink API and its featureset.
Another thing is, I don't see that a large amount of customers would actually buy a ReadyNAS for this, StorageLink is part of Citrix Essentials for XenServer, it's a $3000 add-on per server (gives you other features as well) which you're then hooking up to a single point of failure NAS box. Surely if you need the flexibility and simplicity of storagelink you'll stick faster and proper redundant storage behind it.
