k3v1n
Oct 01, 2013Aspirant
XRAID 2
Hi I have a question, I have the following HDDs available to put in a 314, 2 x 2TB and 2x3TB, now I also have and additional 2x 2TB available I can use, I am trying to maximise the amount of spac...
Oct 01, 2013Guru - Experienced User
The slot order does not matter. If you are inserting the disks one at a time, then you need to insert the smallest disks first. Though on an initial install it is better to just put them all in at once and then power up.
k3v1n wrote: ... does it matter what order the disks go, i.e. do I need the 2 x 3TB drives in slot 1 & 2 or should the smaller 2TB go in slot 1 & 2 and the 3TB in slot 3 & 4...
