coolsnaz
Jul 25, 2012Aspirant
Xraid2 and HDD Upgrades
Hi Guys, I have 2 ReadyNAS units, one is an Ultra 6 Plus and the second is the Ultra 6 Pro. Both have 3x 2TB WD Black WD2002FAEX in an Xraid2 format (2x2TB = 4TB + 1x 2TB Redundancy) Current la...
mdgm-ntgr
Jul 25, 2012NETGEAR Employee Retired
If you started off with one or two disks you would have had a volume of roughly 1.8TB so you could expand to roughly 9.8TB. So depending what you started off with you might be better to backup your data, do a factory default (wipes all data, settings, everything) with your disks in place then restore data from backup
Yes. You can put the first new 3TB drive in either bay. Then once that's synced and expansion has taken place put the other 3TB drive in.
