coolsnaz
Jul 25, 2012Aspirant
Xraid2 and HDD Upgrades
Hi Guys, I have 2 ReadyNAS units, one is an Ultra 6 Plus and the second is the Ultra 6 Pro. Both have 3x 2TB WD Black WD2002FAEX in an Xraid2 format (2x2TB = 4TB + 1x 2TB Redundancy) Current la...
Jul 25, 2012Guru - Experienced User
You're welcome!
BTW, you can save your NAS configuration to your PC, and restore it after the default procedure, which speeds things up a little. If you do this, be careful to re-install any third party add-ons before you restore the configuration. After the config is restored, you can restore the data. Generally I use NFS initially because it is a lot faster. Then I edit the backup jobs to use rsync, and run them again (just to be sure everything is synced).
