starbbs
Oct 16, 2012Aspirant
XRaid2 upgrade 5x2 to 3x2 + 2x3 - nothing happens?
Hello all, i thought i understood the concept, prob not. I have an Ultra6 readynas which first had 3x2tb installed and later on 2x2tb in an XRaid2 setup. So 5x2tbwas installed which gave me prox 7,...
mdgm-ntgr
Oct 17, 2012NETGEAR Employee Retired
You shouldn't see the "Disable Journaling" option any more as that's obsolete. You should see the "Disable full data journaling" option though but that's different.
However if there is the "Disable Journaling" option that should be unchecked i.e. journaling would be enabled.
I agree with Stephen. Open a support case. They should be able to determine why expansion hasn't taken place.
