starbbs
Oct 16, 2012Aspirant
XRaid2 upgrade 5x2 to 3x2 + 2x3 - nothing happens?
Hello all, i thought i understood the concept, prob not. I have an Ultra6 readynas which first had 3x2tb installed and later on 2x2tb in an XRaid2 setup. So 5x2tbwas installed which gave me prox 7,...
beisser1
Oct 18, 2012Tutor
its also possible that hes using dual redundancy.. if thats the case he would need 4 disks of the same size to expand.
edit: cant be dual redundancy. 7.2tb capacity on 5 drives means its single redundancy. please open a case with support.
