InteXX
Dec 29, 2014Luminary
XRAID2 vs RAID6, etc.
I've got an RN104 on the way and I'd like to better understand my configuration options. To start with, I have to admit that I'm planning on using 3x2TB Caviar Greens to start with (WD20EARX); I kn...
mdgm-ntgr
Dec 30, 2014NETGEAR Employee Retired
If your PC is holding the primary copy of the data, then the copy on your NAS is the backup. However the NAS in itself is not a backup. If you store data only on the NAS then it is not backed up.
RAID provides redundancy/high-availability not backup.
Your NAS uses X-RAID2 but the UI calls it X-RAID.
By default an X-RAID volume with 3 or more equal sized (or where only the largest capacity disk has a different capacity) disks will be using RAID-5.
If you switch to Flex-RAID (disable X-RAID) you can choose to have the next disk added convert the volume to RAID-6, then after that re-enable X-RAID again.
Alternatively you could backup your data, switch to Flex-RAID, delete the volume and create a new RAID-6 volume (note a RAID-6 volume requires at least four disks), then re-enable X-RAID.
