nbhatt_14
Feb 09, 2016Aspirant
Zero byte files after NAS failure.
Hi. Newbie here...! I've recently upgraded my Readynas from the DuoV1 to the RN202. Unfortunately my Duo failed (turned on, but fan made loud noise and the power button blinked every few...
nbhatt_14
Hi JennC!
Thanks for the reply.
I tried previously to start the Duo with both disks, then disk 1 alone and then disk 2 alone, but the Duo was continually doing what it has been.
Really frustrated! So not sure what else I should try...
BrianL2
Feb 09, 2016NETGEAR Employee Retired
Hi nbhatt_14,
As JennC previously wrote,
"If you want to see if there is a chance to revive your Duo, maybe you can try contacting support. That must be out of hardware warranty, but they can still perform hardware warranty for free, you also get an option of availing per incident support contract and data recovery service that both have fees."
I guess this is your best bet in getting those files back. Unfortunately, NETGEAR support won't guarantee that the procedure will be a success.
Kind regards,
BrianL
NETGEAR Community Team
- nbhatt_14Feb 15, 2016Aspirant
Hi BrianL,
Would you believe I managed to get the Duo back online!
I changed the memory chip I put in and surprisingly it powered up first time, no issue (so far). I was running a 1Gb SoDimm and just purchased a 512Mb chip and installed it (Corsair). Worked a treat.
Its as it was when I last powered the system down and the zero byte files are available for me to access!
Might be a useful tip for others that get similar problems. Certainly cheaper!
- mdgm-ntgrFeb 16, 2016NETGEAR Employee Retired
The 1GB of 3rd party memory may have been incompatible or may have come loose (e.g. if you moved the unit) or failed. Even if 3rd party memory passes the memory test boot menu option (you should run this at least twice) it may still be incompatible.
Please note that 3rd party memory upgrades are not supported.
You can now mark the post that answered your problem (probably one of your own in this case) as the solution.
