Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
XtheUnknown
Jan 26, 2023Apprentice
Thanks for your thoughts on a potential replacement to readycloud.
My ZeroTier installation fails saying that version >=5 of libstdc++6 is required, but version 4.9.2-10+deb8u2 is to be installed.
I'm on 6.10.8 with KernelPlus installed too.
Any thoughts?
- SandsharkJan 26, 2023Sensei
Did you use the command I gave that retrieves the script and executes it, or did you download a .deb and try to install it? As I stated, there are dependency issues with later versions.
- XtheUnknownJan 26, 2023Apprentice
...just ran the curl command as per your first post. Is there a prior step I should have run?
I have not previously installed/removed nastools app or any standalone .deb
No, that should have worked. The system on which I recently installed it does not have KernelPlus, so that could be a difference. It was actually a legacy NAS converted to OS6, but that shouldn't make a difference. You can download the 1.4.0 .deb and try to install that.
