Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
XtheUnknown
Jan 27, 2023Apprentice
Actually, I installed KernelPlus in the hope that would fix the dependencies (it didn't).
So, I downloaded the .deb files for both x64 and ARM from:
https://download.zerotier.com/RELEASES/1.4.0/dist/debian/jessie/pool/main/z/zerotier-one/
Installed them via the Apps tab
Turned on SSH
Entered the two zerotier-cli commands as per your first post (having already created a zerotier one account and network)
Turned off SSH
...and job done. Thanks.
Although, given the active user community despite the sheer contempt shown by Netgear for its network storage customers, I'm sure other options/improvements will emerge over the next few months.
Am I correct in assuming that I will need to re-install after any update (6.10.9?) to OS6? - Removing ReadyCLOUD will make quite a few settings in the UI redundant, and I wonder whether Netgear will be bothered to tidy things up to remove these.
Leventh
Feb 04, 2023Apprentice
I truly agree with your thoughts about sheering contempt shown by Netgear for its network storage customers and It’s going on for a long time.
