Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
Feb 04, 2023Sensei
If you enable SSH and connect to the NAS as user root and he admin password, you just issue the commands I listed. Or, you can download the arm64 version from the page XtheUnknown pointed to.
Leventh
Feb 05, 2023Apprentice
Sandshark I get it and I would like to thank you for the information and guidance you provided here.
- XtheUnknownFeb 05, 2023Apprentice
...actually I used the armel rather than the arm64 version on my 214, which seemed to work OK (a lot of the other downloadable ReadyNAS apps have .armel file extensions for 10x/2xx systems).
Perhaps Sandshark could advise if there's any importance difference between the two (which are built for different implementations of the ARM architecture).
- StephenBFeb 05, 2023Guru - Experienced User
armel is 32 bit (but of course can run on a 64 bit machine), arm64 is 64 bit.
- SandsharkFeb 05, 2023Sensei
My bad. Yes, the ReadyNAS is an ARMV7 architecture and ARM64 requires V8 or above, you the armel version is the right one.
