Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
JohnNulty
Feb 09, 2023Apprentice
Thanks StephenB, all good points 👍. What about those who may just want to have a 'private cloud' (like 'Google Drive' on a NAS), rather than 'fully fledged' remote access to a NAS, for sharing files with family/friends? I would have thought ZT would be a bit over the top for such use cases.....
Sandshark
Feb 09, 2023Sensei
NextCloud and OwnCloud are excellent for Google drive like file sharing. Unfortunately, the RNXTRAS site which used to have ReadyNAS-specific versions of those available for a small price is no more. The remnants of the site point to his repository of the final versions he created, but I don't really see anything there on how to use it. I find no .deb files that can be downloaded.
Honestly, I think you'd be better off running one of those on an always-on PC (which needn't be very powerful), Raspberry Pi, etc. and then using the NAS for it's storage. At some point, I'll likely convert to this myself instead of OwnCloud on a NAS I currently use for this purpose.
If you were to compile one yourself, you'd have to deal with the back-ports of dependencies (which is one of the reason he stopped development) as well as insuring it is configured so as not to fill the OS partition.
