Sandshark
Jan 25, 2023Sensei - Experienced User
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Feb 12, 2023Guru - Experienced User
Leventh wrote:
Still investigating, how can I do that without an app. running on ReadyNAS...
The other VPN-type solution is to get a router that has OpenVPN. Netgear Nighthawk and Orbi models for example. Then you can install the free OpenVPN app on your phone (or an PCs), and use that to connect to your home network. Once you do that, you access the NAS the same way you do when you are home.
ZT is similar, but rather than giving you full access to your home network, you only have access to the NAS.
