Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
May 17, 2023Sensei
I do not believe that will work any longer due to the changes in the Debian repositories, as outlined above. Whether it will work after updating the repositories list or if you should independently download it and install, I don't know. But it won't hurt to try, and please let us know your results. It has nothing to do with it being a 100 series NAS, though. While the 100 series NAS do have limited RAM, as long as you are not already running a lot of apps, I believe ZeroTier will work. But I own no 100 series to try it on.
Maximus360
May 17, 2023Guide
Sandshark them cli commands do not work as you guessed. I also tried installing the 1.4.0 armel file using the web gui and it fails to install.
Are there any other ways i can get ZT on my NAS 104? I am running 6.10.8 not 6.10.9, sorry.
Any help is appreciated.
