Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
May 19, 2023Sensei
Yes, the 100 series just doesn't have the horsepower for a Plex implementation that requires transcoding. Better to run it on a PC and just use the NAS for storage.
Maximus360
Jun 20, 2023Guide
Sandshark apologies for reigniting an old thread. I have come across an issue where SMB has stopped working to the remote NAS.
Everything was working fine and now all of a sudden I cannot access remote shares.
Windows 10 PC can ping NAS and ZT says both NAS and Windows 10 PC are online.
When I open up my SMB share on windows 10 it says It cannot connect to NAS.
I have disabled windows FW and still no luck.
I can FTP to the shares which is strange just SMB has stopped working.
If I try to set a new SMB share up on my PC and point it to the NAS ZT IP address it says IP cannot be found, yet I can ping the NAS ZT IP fine.
On my mobile everything is working fine so I know the ZT on the NAS is online.
Any suggestions would be much appreciated.
- SandsharkJun 20, 2023Sensei
That sounds like a firewall issue more than a ZeroTier one. Check to make sure your ZT network is shown as private and that your antivirus isn't interfering.
