Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
Jul 09, 2023Sensei
hat would be because there is no such directory. Assuming your data volume is named data. then I assume you are trying to cd into directory /data/temp, so you are leaving out a space.
OldSchoolGuy
Jul 09, 2023Aspirant
Sorry to sound noobish but I am quite confused on what to type in now to install the app manually. What am I going to type in? Thanks again for your guys quick response but I am confused on what to type in now.
- SandsharkJul 09, 2023Sensei
This is now a complex process due to Debian Jessie no longer being hosted on the normal update servers.
- OldSchoolGuyJul 09, 2023Aspirant
how am I going to manually install the app now since the cd/data/temp doesn’t work anymore…. (Or I’m not sure if that’s where the folders are stored). - OldSchoolGuyJul 10, 2023AspirantSorry, wrote the message in a rush. In a better explanation, what I am saying is how can I download it manually then? I tried the cd/data/temp but said no such file or directory via SSH. Where is the apps folder stored on the ReadyNAS 314?
- SandsharkJul 10, 2023Sensei
What, exactly, are you wanting to do? Because there is no reason to go into the apps directory via SSH to install zerotier.
But apps are in /apps, which is just a link to /data/apps (assuming your data volume is named data).
