Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
dhl
Jul 20, 2023Luminary
I'm trying to install ZeroTier on our ReadyNAS Pro 6.
I've read the entire thread and have:
zerotier-one_1.6.6_amd64.deb in /data/Temp. When I try running the install command I'm getting an error where it appears the installer is trying to fetch from an online mirror even though I'm using ./
Here's a readout of terminal:
root@PM-ReadyNAS:/data/Temp# apt install ./zerotier-one_1.6.6_amd64.deb
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'zerotier-one' instead of './zerotier-one_1.6.6_amd64.deb'
The following additional packages will be installed:
iproute2
Suggested packages:
iproute2-doc
Recommended packages:
libatm1
The following NEW packages will be installed:
iproute2 zerotier-one
0 upgraded, 2 newly installed, 0 to remove and 33 not upgraded.
Need to get 426 kB/1,443 kB of archives.
After this operation, 4,321 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 /data/Temp/zerotier-one_1.6.6_amd64.deb zerotier-one amd64 1.6.6 [1,017 kB]
Err:2 http://mirrors.edge.kernel.org/debian jessie/main amd64 iproute2 amd64 3.16.0-2
404 Not Found [IP: 147.75.199.223 80]
E: Failed to fetch http://mirrors.edge.kernel.org/debian/pool/main/i/iproute2/iproute2_3.16.0-2_amd64.deb 404 Not Found [IP: 147.75.199.223 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I've copied and pasted commands from this thread and the .deb is in the right place.
Any advice on what I'm doing wrong and how to fix?
Many thanks!
--David
Sandshark
Jul 20, 2023Sensei
Yes, Debian8 is now archived, so apt cannot fetch those dependancies unless you update the location for it to look and tell it to allow expired signatures. While I believe that was already mentioned in the thread, here is the link again as to how you have to fix that: How-I-got-apt-update-and-install-to-work-with-Debian-Jessie .
