Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
Sandshark
Jul 20, 2023Sensei
Yes, Debian8 is now archived, so apt cannot fetch those dependancies unless you update the location for it to look and tell it to allow expired signatures. While I believe that was already mentioned in the thread, here is the link again as to how you have to fix that: How-I-got-apt-update-and-install-to-work-with-Debian-Jessie .
dhl
Jul 21, 2023Luminary
Sandshark wrote:Yes, Debian8 is now archived, so apt cannot fetch those dependancies unless you update the location for it to look and tell it to allow expired signatures. While I believe that was already mentioned in the thread, here is the link again as to how you have to fix that: How-I-got-apt-update-and-install-to-work-with-Debian-Jessie .
Thanks I saw StephenB's reply first so ignore my previous post. Okay, now to figure out how to make these edits remotely via a macOS SSH terminalđŹ.
Thanks!
ââDavid
