Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
dhl
Jul 23, 2023Luminary
tigerten wrote:I see people is having problem installing the zerotier app. It is actually very simple. Here is how I did mine.
1. Follow Sandshark link to fix your "etc/apt/source.list)
How I got apt update and install to work
2. Download the zerotier deb, in my case it was version 1.8.7
https://download.zerotier.com/RELEASES/1.8.7/dist/debian/jessie/zerotier-one_1.8.7_amd64.deb
This is the most recent version I could install. Nothing after this
3. Install this within the Web Interface through app uploading.
4. login to SSH and type in these:
- zerotier-cli status-->output: 200 info <device address> ONLINE <zerotier version>
- zerotier-cli join xxxxxxxxxx <Your networkID> -->output: Join OK.
- (authorize device in zerotier central)
- zerotier-cli listnetworks--> outputs 200 listnetworks <nwid> <name> <mac> <status> <type> <dev> <ZT assigned ip>
tigerten - Is it possible to use the ZeroTier app GUI with this install method?
tigerten
No.
Zerotier GUI does not really do much.
the setup is one time thing. once up, it is care-free. As you can see, it is just one line: join the network.
