Sandshark
Jan 25, 2023Sensei
ZeroTier as a ReadyCloud replacement.
Well, a big part of a replacement, anyway. With ReadyCloud going away, a lot of folks are going to be looking for a replacement in order to have remote access to their ReadyNAS, I have been using...
tigerten
Jul 28, 2023Luminary
1.8.4
Web install and cli install behave differently. I don’t know why and how. I had better chance of success with web install. The dependencies it needs during cli install are not required if doing it via the gui.
You may have to reset your system. Or reinstall the OS.
dhl
tigerten wrote:
1.8.4
Hmmm, that's odd. 1.8.4 failed for me after a fresh install of OS 6.10.9. I'll try CLI again after running apt-get update. This definitely feels like voodoo...
- tigertenJul 28, 2023Luminary
try install this first:
https://archive.kernel.org/debian-archive/debian/pool/main/i/iproute2/iproute2_3.16.0-2_armel.deb
- StephenBJul 29, 2023Guru - Experienced User
fwiw, 1.8.4 installs on my rn102 (running 6.10.9)
root@RN102:/data/Test/ZeroTier# apt-get install ./zerotier-one_1.8.4_armhf.deb Reading package lists... Done Building dependency tree Reading state information... Done Note, selecting 'zerotier-one:armhf' instead of './zerotier-one_1.8.4_armhf.deb' The following additional packages will be installed: gcc-4.9-base:armhf iproute2 libc6:armhf libgcc1:armhf libstdc++6:armhf Suggested packages: iproute2-doc glibc-doc:armhf locales:armhf Recommended packages: libatm1 The following NEW packages will be installed: gcc-4.9-base:armhf iproute2 libc6:armhf libgcc1:armhf libstdc++6:armhf zerotier-one:armhf 0 upgraded, 6 newly installed, 0 to remove and 33 not upgraded. Need to get 4,788 kB/5,582 kB of archives. After this operation, 13.4 MB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://archive.kernel.org/debian-archive/debian jessie/main armel iproute2 armel 3.16.0-2 [384 kB] Get:2 http://archive.debian.org/debian-security jessie/updates/main armhf gcc-4.9-base armhf 4.9.2-10+deb8u2 [160 kB] Get:3 /data/Test/ZeroTier/zerotier-one_1.8.4_armhf.deb zerotier-one armhf 1.8.4 [794 kB] Get:4 http://archive.debian.org/debian-security jessie/updates/main armhf libgcc1 armhf 1:4.9.2-10+deb8u2 [39.8 kB] Get:5 http://archive.debian.org/debian-security jessie/updates/main armhf libstdc++6 armhf 4.9.2-10+deb8u2 [241 kB] Get:6 https://apt.readynas.com/packages/readynasos 6.10.9/main armhf libc6 armhf 2.19-18+deb8u10.netgear1 [3,963 kB] Fetched 4,788 kB in 2s (1,644 kB/s) debconf: delaying package configuration, since apt-utils is not installed Selecting previously unselected package gcc-4.9-base:armhf. dpkg: warning: files list file for package 'libclamav9:armel' missing; assuming package has no files currently installed(Reading database ... 18788 files and directories currently installed.) Preparing to unpack .../gcc-4.9-base_4.9.2-10+deb8u2_armhf.deb ... Unpacking gcc-4.9-base:armhf (4.9.2-10+deb8u2) ... Selecting previously unselected package libc6:armhf. Preparing to unpack .../libc6_2.19-18+deb8u10.netgear1_armhf.deb ... Unpacking libc6:armhf (2.19-18+deb8u10.netgear1) ... Selecting previously unselected package libgcc1:armhf. Preparing to unpack .../libgcc1_1%3a4.9.2-10+deb8u2_armhf.deb ... Unpacking libgcc1:armhf (1:4.9.2-10+deb8u2) ... Selecting previously unselected package libstdc++6:armhf. Preparing to unpack .../libstdc++6_4.9.2-10+deb8u2_armhf.deb ... Unpacking libstdc++6:armhf (4.9.2-10+deb8u2) ... Selecting previously unselected package iproute2. Preparing to unpack .../iproute2_3.16.0-2_armel.deb ... Unpacking iproute2 (3.16.0-2) ... Selecting previously unselected package zerotier-one. Preparing to unpack .../zerotier-one_1.8.4_armhf.deb ... Unpacking zerotier-one (1.8.4) ... Processing triggers for systemd (230-7~bpo8+2.netgear3) ... Setting up gcc-4.9-base:armhf (4.9.2-10+deb8u2) ... Setting up iproute2 (3.16.0-2) ... Setting up libc6:armhf (2.19-18+deb8u10.netgear1) ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline Setting up libgcc1:armhf (1:4.9.2-10+deb8u2) ... Setting up libstdc++6:armhf (4.9.2-10+deb8u2) ... Setting up zerotier-one (1.8.4) ... Processing triggers for libc-bin (2.19-18+deb8u10.netgear1) ... Processing triggers for systemd (230-7~bpo8+2.netgear3) ... N: Can't drop privileges for downloading as file '/data/Test/ZeroTier/zerotier-one_1.8.4_armhf.deb' couldn't be accessed by user '_apt'. - pkgAcquire::Run (13: Permission denied) - SandsharkJul 29, 2023Sensei
So it appears that folks are not reading the entire thread regarding the repository changes, especially my very recent summary where I added http://archive.debian.org/debian-security per one of the other contributor's recommendation. That's where your install found the libcstd++6.
- StephenBJul 30, 2023Guru - Experienced User
My install was done with your sources.list and apt.conf, so it did include this repo.
BTW, I was able to install the newer 1.8.7 on arm after this. The trick is to run
apt-get install openssl:armhbefore you install zerotier.
- DuckSoupNAS1Jul 30, 2023Aspirant
Feeling more and more a newbie... where do you get the source for openssl:armh?
- StephenBJul 31, 2023Guru - Experienced User
I didn't. I just typed in the command as I posted it above. This was with Sandshark's apt.conf and sources.list placed in /etc/apt
Can you post the sources.list and apt.conf you are using?
