Hannu's avatar
Hannu
Follower
Apr 10, 2023
SUGGESTION: e.g. Nighthawk Pro Gaming, Dashboard "Monthly usage"
Add simple options to
a) Add e.g. 25GB to plan limit
b) Reset Plan limit to a specified value
... on "Billing start date"
Nighthawk Pro Gaming, <- included due to restriction on posting.
Nighthawk M1 MR1100, FW NTG9X50C_12.06.39.00
1 Reply
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Hi Hannu,
    thank you for the nice suggestion and your engagement . I referred it to the appropriate department so that we can deal with it.
    I wish you a nice day!
    Kind Regards,
    DamianM
    NETGEAR Community
