Uffe1959's avatar
Uffe1959
My RN312 is super slow on resync after new disk has been added
After firmware update to 6.10.3 I started to look at the logs and saw increased ATA errors. Since the NAS is 7 years old I thought it might be a good opportunity to start exchange of the disks.
I bought a new Toshiba 2TB similar to the old one and replaced in NAS.
NAS is set as X-RAID.
Apr 09, 2020 10:02:11 AM
Disk: Disk Model:TOSHIBA DT01ACA200 Serial:Z9A17S2AS was added to Channel 2 of the head unit.
Apr 09, 2020 09:59:50 AM
Disk: Disk Model:TOSHIBA DT01ACA200 Serial:33GTP6GGS was removed from Channel 2 of the head unit.
Apr 08, 2020 08:20:25 PM
Disk: Detected increasing ATA error count: [101] on disk 1 (Internal) [TOSHIBA DT01ACA200, 33GKGMBGS] 14 times in the past 30 days. This condition often indicates an impending failure. Be prepared to replace this disk to maintain data redundancy.
Apr 08, 2020 10:37:50 AM
Disk: Detected increasing ATA error count: [39] on disk 2 (Internal) [TOSHIBA DT01ACA200, 33GTP6GGS] 19 times in the past 30 days. This condition often indicates an i
Now the resync has been running since the 9:th of April and is still on 21 % and calculates 8000h:s, sometimes 20000h:s.
Is it time to buy a  totally new NAS or is it repairable ?
I have tried some commands like: hdparm -W 1 /dev/sda
but it does not seem to turn on write cache for sda, it still says  (off)
However it seems to work for /dev/sdc.
See attached gif
  • Hello Uffe1959 ,
    Welcome to the NETGEAR community! :)
    You should make a backup of the data first of all (on another support) as long as you have access to it.
    The errors come from the drives, so the chassis is probably not faulty.
    The sync probably takes so long because there is drive failing there and with the constant read/write operations of the sync the ReadyNAS might struggle if a drive is bad.
    Could you send me the logs via MP, please?
    Have a nice day,
    Valérie D
    Netgear team
  • ValerieD's avatar
    ValerieD
    Community Manager
    Hello Uffe1959 ,
    Have a nice day,
    Valérie D
    Netgear team
    • ValerieD's avatar
      ValerieD
      Community Manager
      Hello Uffe1959 ,
      So, the logs are confirming what I previously advised.
      Replacing faulty drives would be the best solution.
      Did you manage to make a backup on another support?
      Have a nice day,
      Valérie D
      Netgear team
      • Uffe1959's avatar
        Uffe1959
        Hi !
        I have bought 2 new similar disks to the ones previously installed.
        Now system reports 11 hours to complete resync, it looks like almost 90% of the data was synced on the new disk I installed beginning of April.
        The earlier resync never reached 20% and expected finalization was in 25000 h ... but some how 390 Gb of around 420 is on the new disk.
        I still have most of the data on other disks/laptops but a thing like this makes you start to plan for a backup solution of some sort..
        Thanks anyway !
        BR
        Ulf
