Miadi's avatar
Miadi
openvpn 证书问题
说明:出厂固件版本1.0.1.36可以使用vpn。
第一台R9000,升级固件1.0.3.10后,openvpn证书丢失,导致不能使用vpn。
官方客服换了一台新机,并告知我1.0.3.10有bug,可以使用1.0.3.6,于是把第二台R9000升级到1.0.3.6,证书没有丢失,但是过期了,过期时间是1902年。
降级固件也没用,证书不更新,一直是过期的证书。
现在客服没有给出解决方案,也不能给解决,只说向研发报bug。
我花了3000元买了一个全世界最牛逼的路由器,现在出问题没人给解决。
我一次一次的电话邮件沟通,刷新各版固件,无偿的为你们做测试,现在没有任何一个人能给我一个明确的答复,只跟我说抱歉。
  • schumaku
    mingle123
    更新到1.0.3.6,openvpn的证书日期就会变成 2018年12月1日 - 1902年x月x日,不仅仅是ca.crt/client.crt/client.key,server的证书也如此,cat一下easy-rsa中的所有文件,日期都是如此。。
    现在我修改了一下vars,和服务器时间,只生成10年的,截止日期就不会变成1902年了。
    具体方法在上面的附件中。
    Hello Miadi,
    感谢您对NETGEAR的支持!
    关于R9000 VPN证书的问题,研发提供了以下修复版本,请下载更新。若问题未能解决,请及时与我们联系。多谢您的理解和配合!
    • Miadi's avatar
      Miadi
      你是谁?1.0.3.16固件是官方发出来的吗
      • schumaku's avatar
        schumaku
        This is R9000-V1.0.3.16.img image is identical to the one I have received from Netgear for testing - bit by bit, and same md5 checksum.
        Further on it does come with the updated dnsmasq.
    • Miadi's avatar
      Miadi
      请您看一下我的解决方法,还需要怎样修复,毕竟这个服务器时间还有问题
  • schumaku's avatar
    schumaku
    Hi Miadi
    To the extent I think I understand Chinese your R9000 has a certificate with an expiration date in 1902. No idea what can cause this - seen at least one more similar report some days ago here in the community.
    The Nighthawk firmware does usually come with a factory (hard coded) certificate, signed by Entrust, that's the one I have in place since 1.0.3.10 - conclude, there is a problem with some, but by far not all R9000 updated:
    This kind of factory certificate is also the reason why older firmware - which held indeed an expired certificate (but not back as far as 1902) - can't be used anymore.
    Digging again with the Netgear product engineer.
    (Edit:)
    If you have a minute - please download the OpenVPN Windows config from your R9000, unzip, and open (double click) ca.crt and client.crt - post the certificate overview and details.
    The older certificate set was valid from 25-APR-2014 ... 22-APR-2024, the one I have here on my R9000 is valid from 26-APR-2017 to 21-APR-2037. Curious about yours.
    (Edit end.)
    -Kurt
    PS. Take this as another complaint AbhayB and NaderA - it's ridiculous how unreliable your supposedly leading edge (and expensive!) products are.
    • Miadi's avatar
      Miadi
      不知道为什么,附件中文本内容不能发到论坛,发出来就被删掉了。
      请你们看一下我的解决方法,帮我完善一下,服务器的时间还是有问题的
