Hi There, can I asked to fix the Mikrotik Romon in all of your Switches, I saw its fixed for M4200 and M4300 not for M4100 and others, Thanks.
3 Comments
- df3eiNovice
I support this, however, I have two GS724x, one of which does pass ROMON packets, the other one doens't...
- bsz786Novice
I have GS716Tv3 and im having the same issue.
What can I do?
Case no 43363127
- DaneANETGEAR Employee Retired
Found out from NETGEAR Support that your case # 43363127 got closed due to no response at your end. It is because the Level 2 Support Expert who is assigned on your case tried to call you back several times on the contact number you have provided but it seemed to be invalid and there is no option to leave a voice mail. Also, follow-up e-mails were sent to you and you only replied once when you provided your contact number then after that, no response at all from your end.
DaneA
NETGEAR Community Team
