SgtBob's avatar
SgtBob
Follower
Apr 15, 2020
Status:
New Idea
Orbi Pro - Attached Devices Bandwidth Usage
I have two requests, 1) Being the most important and 2) being less important.
1) Per attached device real-time bandwidth monitor. Consider the scenario that a connect device is utilising too much bandwidth and slowing other users. You can’t easily identify the culprit at present.
2) Historical bandwidth and traffic stats, per attached device. Allowing you to identify large upload and downloads, etc., and View usage patterns.
Thanks for the consideration.
1 Comment
  • I agree. That is a basic troubleshooting tool that should be included on a product at this price point.
    Synology routers have this as an option. You can drill down by client, application, etc. I currently use synology routers and use the Orbi Pro system for wifi. This shouldn't be necessary for a "professional" level product.
