We are looking to use manage accounts for households using Insight and the Orbi Pro. Right now, the Insight portal needs some help. Here are some things I wish it could do:
- Allow you to rename clients so they are identified easier
- Only the Router shows up in devices and not the satellite so if someone unplugs the satellite, you don't get any kind of a notification.
- No way to set up port forwarding remotely. Have to use the local orbilogin.net and be onsite
- If you make a change using the cloud, there is nothing that tells you that config is being pushed to the devices. They should have a status like "configuring" or something... You just have to wait and hope the the command worked.
- I will say that the portal and app make it very hard to find information. Like notifications being under Account Management? That is very un-intuative.
Other than these things and the delay of using the cloud, I think it is a good solution. It just needs some work.
No CommentsBe the first to comment
