Music-IT's avatar
Feb 04, 2024
Status:
New Idea
Set Custom Speed Test Server
Hi,
Using Insight we can do a speedtest to see how fast the connection is. I’m using a PR60X with a 4Gbps fibre connection but running speedtest from the router (both via Insight or the local GUI) it doe not reflects my line speed. Using a computer wired connected to the 10Gbps lan port is works just fine BUT I have to select a specific speedtest server. It seems not all servers ready for testing a high speed connection.
So I would like to have a feature what gives me the option to select a speedtest server manually!
Rgd
Rob
11 Comments
