Azmann's avatar
Azmann
Status:
New Idea
4G+ or LTE-A icon on lcd screen and app or web interface
Hopefully netgear team can impliment 4G+ or LTE-A on LCD screen or apps or web interface. Since not all place or spot have 4g+ or lte-a, it is good for mobile router to impliment some icon to indicate 4g+ status. It will help user to find the best spot to park the modem. All android phone have this feature.. and most high end modem such as huawei has indicator or icon to show current 4g status. It guide the user a lot to get best available connection from the modem.
Furthermore.. i cannot find carrier agreegation info such as which band are agreegate from apps or web. But this info is available inside AT!GSTSTUS? command.. which very restricted and can only be acess thru usb connection. For adavance user.. this info also help them to analyze connected speed  thru band agregate. Huwaei is putting this info thru their web or apps. Netgear should put this info for easy to access.
Comments have been turned off for this idea
