I have a Cisco Air 3600 Access Point, and I have multiple SSID's that I am broadcasting from each radio (3 SSID's on the 2GHz radio and 3 SSID's on the 5GHz radio). The X6S will only extend 1 SSID pe...
whoa_there
Sep 24, 2020Follower
Im not sure I am getting what you are explainging. Broadcasting a SSID (or more than 1 SSID) doesnt have any impact on anything, now if smultiple things uses multiple SSID's on the same radio then sure that radio is impacted, but at the speeds each radio has, for my purposes the bandwidth can be split just fine. I just dont see why multiple SSID's cant be broadcast on the same radio is all.
