tucsontico's avatar
tucsontico
Virtuoso
May 14, 2019
Status:
New Idea
Allow Variable Power Output on ORBI satellites
I beleive it would be extremly helpful to allow ORBI owners the ability to change power levels on  satellites by frequency, e.g., 2.4 gHz and 5 gHz. This option may help some owners to eliminate crosstalk between satellites and constant device switching between satellites in certain situations.
1 Comment
Comments have been turned off for this idea
  • This can be done. If you go to advanced settings and from their into wireless settings, you can adjust the power transmission for each band.
