Hi, I have a lot of devices attached to my router. I try to keep things organized so I can see what is attached in the Attached Devices screen. Can Netgear please add the option to upload a custom...
migbox
Jan 06, 2018Follower
I'm totally agree, much icons missing..i.e. Inverter or Solar panels
I think the best way would be to give the user the freedom to add their own png files.
I suggest what follows:
- when chosing Other device, a popup window will open and give you the way to pick a png/jpg file from your drives
- then Genie would copy the file into their folders and use it in association with the selected device
