Hi, I have a lot of devices attached to my router. I try to keep things organized so I can see what is attached in the Attached Devices screen. Can Netgear please add the option to upload a custom...
CR125Honda
Jul 19, 2019Onlooker
Thanks for the update.
Sounds like you've got it figured out!
Statrted looking into your instructions and I'm hesistant, thinking I'd mess up the router.
Command prompt I'm comfortable with.
But no programming experience or software that might be needed (?) to do this editing.
Would need a walk through for a Window 10 PC.
