Your routers should use built-in VPN functionalities of Windows, macOS and Android instead of using 3rd party apps. Ideally you give the informations needed by each OS and a clear step by step guide if needed.
2 Comments
- privacychairAspirantHere is a good guide for setting up a VPN on Windows 10 without having to install an app. https://www.magnumvpn.com/setup-vpn-windows-10-l2tp-ipsec.html
- AbhayBNETGEAR Employee RetiredStatus changed:UnspecifiedtoResolved
We have chosen to use OpenVPN as a popular solution on the router. When you do turn the feature on, the instructions are provided for each of the OSes. You can refer to https://kb.netgear.com/29783/How-do-I-use-VPN-service-on-my-Nighthawk-router-with-my-Android-device for example.
