Dear all,
I must say I'm quite satisfied with this wifi extender, just to give a glance I get more than 30 mbits on 50% power transmission using fast Lane technology, I couldn't ask for better.
However, I would like to ask for developers if possible to add on future firmware updates an option to disable leds blicking and to disable all leds, mainly because I use the repeater on my bedroom and is annoying all those lights all night long, moreover I know through skimming on this forum, that some models from net gear come with that option on their firmware, is it possible to port it to this device.
In regards to schedule on Wifi, albeit not sending any data through the Wifi connection, when disabling Wifi, is it possible to disable also SSID?
Regards
Comments have been turned off for this idea
