While it's great that we can designate our own DNS servers on the routers, instead of just using the ones provided by our ISPs, it would be even better if you could integrate DNS-over-TLS and/or DNS-...
Feb 12, 2024Guru - Experienced User
"DNS-over-TLS and/or DNS-over-HTTPS" - Most of that is handle by browsers or features with in browsers. Also can use custom DNS servcies and there IP addresses with in the router configuration. Nothing would need to be added here.
Most likely something NG may not want to get involved with.
