californiaman
Jan 18, 2016Tutor
Status:
Unspecified
Give an option to use external USB connected portable HDD to increase stored log file size
I have a R7000 router. I found out the current log size is very limited and I want it to log 24 hours events. I guess saving log on router has file size limitation.
As I know, R7000 router can connect to a portable USB hard drive directly and can use it to do backup files. Why not use it to store the log data file? By doing it, the router can store any large log file size as long as the hard drive has the capacity. I think it is feasible and not hard to implement this as Router can access this hard drive directly and already provided some file back up features.
Please Netgear change some configuration to add this feature. That will be great!!
1 Comment
- William10aMaster
A simulator feature exist on windows 7 and up it is call ready boot it save files on a usb flash drive and loads them back when the loads windows when you boot your up. A version of this ideal would save logs very easy and free up memory in the router for other task.
