Netgear, please DO NOT DISPLAY the WiFi passwords in the clear for the primary and guest networks on the default Basic -> Home page of the http://orbilogin.com web interface. The passwords should not be displayed on this page at all, instead it would be more helpful to display the encryption being used on both the Primary and Guest WiFi networks for this status page. Please correct this security issue! The password can still be shown when uncovered on the WiFi Settings pages if needed, else it should only show *********** to hide the SSID password. There is absolutely NO REASON to display PASSWORDS IN CLEAR TEXT on the home page!
10 Comments
While this is only visible if someone logs into the router's web interface, it's still a glaring security vulnerability. Should I get privacy filters on my monitor because Netgear couldn't be bothered to mitigate the very real risk that any Tom, Dick, and Harry could literally read the password over my shoulder? What if I took a screenshot of the router main page to send it to someone (for whatever reason)? Should I also accept the fact that the password would be visible to anyone who receives the screenshot and so, I'd have to change the password?
Fix this, Netgear!
The display of clear text is only administrative intended for use with the 1 admin user who manages the routers web page. It is intended to be in the clear so one can have a quick check to see what the password is, while the config page does have it hidden with (*). So something that NG would not change. Again only the admin user would have access and have the need to see this. This is not a security risk.
Enjoy.
- T5Novice
Agree. My RS600 does this too.
- gregorioandadorFledgling
Adding my two cents. Seems pretty serious and should not be shown by default on a home page. Makes me wonder if Netgear takes security seriously and what else is insecure in the internals of the router.
I would be okay with the "eye" button on the home page with the wireless areas like what is on the "wireless settings" page. Even then it's much safer to just be able to see the password in one place and that via the "wireless settings" page.
- CWafflesTXAspirant
I completely agree with this. This should be a VERY easy fix for Netgear. Any network security person in the world will tell you that you should never have a password in plain text that on a main home screen. Seriously Netgear, take security a little more seriously.
- arrasmithNovice
Reported almost 2 years ago. Should be a simple fix. PLEASE fix this. I have a couple friends/neighbors I have convinced to buy the ORBI and when I have to go and show them something, there in plain site is my network password. I would really appreciate either astericks with the click on eye to view passwords -or- remove the password from the widget and link to the other page that already has the astericks implemented. Thanks :)
Yes, I agree. Do not show passwords in plain text ANYWHERE! All the Netgear router control panels do this. It's insane that Netgear thinks this is ok. netgear Obscure the password in router control panels! Let the admin view it by "clicking to unmask".
- dlrossFollower
Absolutely agree on this
- iceblinkAspirantTotally agree, and I hope Netgear will address this issue even when only a few kudos are given!
I totally agree with you on this. I don't even like storing passwords in plain text on Linux systems where that is required. If there was a way around that I wouldn't either. I did not like seeing the passwords in clear text on the landing page of the router though, I know that has to be a security issue.
