Regarding LB2120-100UKS.
The Network selection and Data connection options are far too limited to provide any real use from the device. We require the ability to manually select not only the ty...
electroMechanic
Aug 07, 2018Star
Just to add a little context, while the device was connected using band 20, the signal strength indicator was showing 4/5, whereas while connected using band 3, the signal strength was showing 2/5.
So the connection using band 3 was actually yielding a substantially superior download speed despite the fact that signal strength was apparently half that of the connection using band 20.
