Regarding LB2120-100UKS.
The Network selection and Data connection options are far too limited to provide any real use from the device. We require the ability to manually select not only the ty...
michaelkenward
Feb 16, 2020Guru - Experienced User
psynpase wrote:
unless I am mistaken the band numbers are fixed, it is just the priority that you can change ..... and I believe those band numbers to be specific to the North American market
Probably down to the regulators.
This is certainly the case for wifi bands. Locked in the USA, but available for user tweaking in some other markets.
If seems to be down to the FCC, there is nothing that Netgear can do about it.
Does anyone know how this works with other brands?
