toyshop's avatar
toyshop
Follower
Nov 13, 2017
Status:
New Idea
LB2120 LB1120 send email instead of sms
Hello,
 Have written before but never had a reply. I need my LB2120 LTE modem to send me a message when it fails over to 4g but I cannot find a data plan that also will send a text so it would be great if we had the option for sending an email. Has anyone else found a carrier that sells a pay as you go data plan that will also send a sms message?
Thank You, Troy
5 Comments
  • Where are you based? I'm ion the UK and my EE SIM sends SMS even though it is a data only account... Guess it depends on your local telcos. Worth trying to send an SMS from the modem with your current SIM if you haven't already
  • I am having the same issue and I second this idea. Having the option to put in SMTP settings to send an email would be very helpful.
  • I am in Australia and have the same problem with Telstra and Vodafone. SMTP would complicate a simple product but it is quite important to know when one is failedover (if there is such a word )
  • Long story short, when I returned from being out of the office the internet was running slow. I checked my connection source and I was running on cell data. All I had to do was restart the modem and I was back online. I just ate through GBs of data and an extra cost.  An email notification would have been key and would have saved me money.
    Please implement =)
  • This would be a very useful feature.  I am using a "Three" data sim in the UK.  It does not allow sending SMS messages, so I receive no notification of a loss in wired connection and all my data gets used up.
