Tellurium's avatar
Tellurium
Apprentice
Sep 07, 2018
Status:
New Idea
[LB2120 successor] - 4 SMA connectors for external antennas and faster modem
Hello
If you decide to use a mcuh faster modem for the LB2120 successor, let's say the X24 LTE 2Gbit/s modem from Qualcomm (The Netgear MR1100 uses the X16 - 1Gbit/s), I would suggest, to add 4 external antenna connectors and not only 2 (from the 4 available) as on the MR1100.
Additionally it would be greate to use SMA connectors, instead of TS-6, they are much more robust. I understand that you make use of TS-9 connectors on portable modem, but since the LBxxxx serie has be designed to be used on a LAN for home or small businesses, it make sens to use a more reliable connectors.
Comments have been turned off for this idea
