make a new firewall settings
maake a profecional foresic firewall and strong level of security
make to set diferent levelof security
firewall off
firewall low
firewall medium
firewall high
firewall extreme security
add turbo turbo firewall and nat aceleration x50
and no matter what security you set that you can play games with nope problem
make to set rule or block any ip ,server,dns,,mac ect
and firewall monitor you can see all trafic and pagake reach and attack or something rare or hakers try to break in ect
add strong hardware encription 512bit or 1000bit or higther
add new firewall encription.. encrip your network no matter what you go or what site your enter or sever ect and state secure
and your network will always be encripted and will be more complicate to haker bypass the security
fix firewall slowdonw when recive alot of junk over the network or attack or malware ect fix that the modem start slowdonw
add strong https longin and ect everywhere
reinforce webpage security https or trafics
add strong anti exploit for all and new zero day attack
make infected scrip blocking
make infected cookie protection
add for the first time adove flash protection to prevent any attack or hole or exploit
fix the slowndow dos sistem and portscan when you play on gamming feel slow
add deep protection scan dos and portscan ect
add all this to support ip 6 too
just helping
2 Comments
- Yes can can concur but I would see it on R8000 or 8500 due to CPU and RAM available! - Otherwise introduce a raspeberry pi as a firewall in future devices!
- yup
